and the word I should have used was indeed "durable" to express
what I really intended to.
So let me restate more accurately. Certainly COLORiT is .....
indeed much more durable than enamel.
However it certainly looks like enamel and is more durable than
enamel.
g’day Elaine - if we are to start from a common base in this
discussion it would be helpful to agree on some definitions. For
example, how would you define “durable”? The simplest definition I
could find was "durable. a. lasting, resisting wear. Common synonyms
aRe: "abiding, constant, dependable, enduring, fast, firm,
hard-wearing, persistent, reliable, resistant, sound, stable, strong,
sturdy, substantial and tough. The same source defines “much” a. as:
existing in quantity and “more”. a. as: greater in quantity or
number.
If you accept that these are reasonable definitions I would ask you
again to either present to the Forum the factual basis for your
extraordinary claim or point us in the direction of the Standards
facility that conducted the comparative tests on which you are
basing this claim.
I’ve included for Orchidians a link to the website of the
manufacturer of Colorit, Inovis Aktiengesellschaft , along with a few
direct quotes from the site which are interesting as much for what
they don’t say as what they do. There are some good pictures of
pieces embellished with Colorit in the “Fascination” section.
Inovis is a large, reputable company and nowhere on their excellent
site do they even mention the word “enamel”, let alone compare
Colorit to enamel. They, unlike over-enthusiastic salespeople
(grins), are open to constant scrutiny and examination by their
industry peers and regulatory bodies.
http://www.inovis.li/E_Willkommen.html
The below was copied directly from this site, and the
exclamation marks are theirs. The italics are mine.
“Colorit - The new colour system A growing number of consumers are
very discerning and know exactly what they want. Expressing their
individuality is important to them. Design and quality, therefore,
play a key role in satisfying their requirements. The Colorit
material from Inovis responds to this demand. On the basis of this
newly developed ceramic-reinforced composite material, it is now
possible to create colourful decorations for jewellery pieces and
accessories in an innovative way. This new perspective offers
additional sales opportunities for goldsmiths and jewellery
workshops.”
- Fundamentals Optimum bond Mechanical and chemical bonding of
Colorit!
mechanical: undercuts chemical: Colorit Link and Colorit Bond If
surfaces are sandblasted (250 =B5), the colours are chemically bonded
using Colorit Link If surfaces are ground or polished, the colours
are chemically bonded using Colorit Link and Colorit Bond
Colorit Bond does not have to be used if the inlays are small.
Undercuts, however, are imperative. Sandblast surface and use Colorit
Link.
Undercuts are absolutely necessary for an optimum bond! Inlays must
not be thinner than 0.8 mm!
- Finishing
" Colorit can be ground, polished, sandblasted, or turned on a lathe
(high rpms). Do not engrave Colorit with a hand tool! Machine
engravings are possible at high rpms.
Do not heat Colorit inlays over 100 degrees centigrade!
Remove cured inlays by cutting or burning them out."
"Slight shrinkage
The fact that Colorit shrinks slightly must be taken into
consideration when applying the material. Therefore, use a little
more material than necessary and slightly overfill the cavity".
A wise craftsperson would think through the implications of the
“shrinkage” and “heat” statements given that the material is a
photoresin and unless completely cured at the time of application
will continue to cure while exposed to actinic light.
cheers
Al Heywood
