Gentec torch oxy won't flow
#1
I have had the Gentec torch for several years, worked fine. Now the
oxygen doesn’t want to flow. Seemed hard to get flowing the last
couple times I used it (removing the regulator and replacing and
opening/closing valves seemed to get it running). But today I
couldn’t get any oxygen at all. Tested the tank, it is not empty.
Should I have to get a new torch? I’m guessing it is not easy to
repair if the regular is Kaput. Anyoneelse had this problem?
Todd Welti
Livingcoloropals.com
