Hi there, I have a Midget torch. I would like to know what the
pressure on the Oxygen and Propane gas tanks need to be so I could
start soldering. No one seems to know, not the store that sold me the
tank, nor the gas station that filled it up! Can someone please
help?
Thanks
Pouneh
P.S. this is my first time posting a message. Oooooh!
I have a Midget torch. I would like to know what the pressure on
the Oxygen and Propane gas tanks need to be so I could start
soldering.
I use a Midget, with propane set at 4-5lbs, and oxygen at 7-8lbs,
for daily bench work. You can then, of course, regulate further at
the torch body.
Matthew Crawford
www.MatthewDesigns.com
I have not looked at the guages in a while but the propane is about
4lbs and the oxygen is about 5 lbs. Light the propane first, about an
inch of flame and then add oxygen. If the oxygen blows out the
flameā¦reduce its opressure.
mike w Arizona
www.azbeaddepot.com
