I’ve been using pressure reduction valves for very many years on
both oxygen and propane bottles to provide a line pressure of around
5 pounds per square inch. Before I began jewellery work I did quite a
good deal of scientific-equipment type glassblowing using Pyrex (soda
-or ordinary glass doesn’t really need oxygen) and always found these
pressures perfectly satisfactory, even when very large flames are
required. (making large flasks from tube, for instance) But I have to
emphasize that you ** MUST** use pressure reduction valves, and one
should also have anti-flashback devices too, to be really safe.
But I have to emphasize that you ** MUST** use pressure reduction
valves, and one should also have anti-flashback devices too, to be
really safe.
If you use O2 then a flash back is advised, but for straight propane
it isn’t necessary, as long as you check the hoses and connections
regularly (but you must check).
really safe.
Hi John, Why not use a regulator rather than a pressure reduction
valve? Or are you referring to a regulator? I prefer an adjustable
valve, then you can change your pressure as needed. I’m not picking
at you, just trying to understand whether you are using a preset
pressure reduction valve or an adjustable regulator as I am
accustomed to seeing. I certainly agree with the need for flashback
arrestors!
