Forwarded Message FollowsDate: Sun, 20 Oct 1996 11:36:52 +0100
To: service@ganoksin.com
Subject: Re: Orchid D - I - G - E - S - T Oct 96 # 004
Nice One!
I use piano wire from the very high notes, I found an old broken
joanna and canibalised some of the pieces for our workshop. Will try
your idea sounds just great Many thanks
Tony H
Soldering pick
Date sent: Sat, 19 Oct 1996 15:50:17 +1200
Referring to the thread on soldering, has anyone else tried a
piece of titanium wire about 2 - 3 inches long with one end
mounted in a piece of wooden dowel, and gently pointed at the
other end? You can dip it in a little liquid flux, then pick up
a tiny paillon of solder about half a mm square, gently heat it
with a soft flame, when it will roll into a ball. Then having
heated your work to soldering temperature, apply the solder ball
to the right place - and it will flash into the joint if the two
pieces of metal are properly prepared and touching exactly. I
couldn’t buy Ti wire, but bought a pair of coiled wire earrings
and unwound the coloured spiral The point of Titanium is that
nothing will solder to it (without special equipment.)
