Fordom quick release, doesn't take other bit sizes
I bought a Foredom kit with an easy change handpiece. I didn’t realise I could only use one size drill bits. I have a lot of other sized bits. What now?
Do I have to change the handpiece?
Sorry to be there bearer of bad news, but yes most quick release handpieces take 3/32" flex shaft parts. There are a couple of solutions.
One is to get an inexpensive #30 handpiece just for off size flex shaft parts, like your drill bits. Changing out flex shaft handpieces is very easy. You can find genuine Foredom #30’s for around $80 and other brands under $40.
Another solution is to buy drill bits designed to fit a quick release 3/32" collet.
What I did when I switched over to a quick release system, over time when I needed new flex shaft parts, I only bought 3/32" flex shaft components. After a while most of my parts were 3/32". I do have a #30 handpiece for when I need it.
I find having a quick release system to be helpful and efficient. Hopefully you’ll find that too!
Jeff
You can buy sets of drill bits in different sizes but they all have a 3/32 drive shaft, so they will all fit your flex shaft quick change…Rob
Hi,
you could eventually get a Foredom #30 handpiece with a jacobs chuck and key…
they come in handy…they close down to 0…and open up pretty wide…
can accomodate wire for twisting, q-tips and toothpicks for polishing🤣…very small drill shaft sizes…
they run around $75-80 usd
i have a quick change handpiece as well, but i tend to use my #30 alot…it is a fatter and shorter handpiece…comfortable for me…seems to have a bit less “flailing” of the flex shaft cable…so less hand stress for me…
in addition to silver color, they fome in fun colors like pink and blue as well…
julie
