Hi David
This is a bit difficult for me to describe with actually showing
you, but I’ll try.
The tool used is a pointed burnisher, every setter probably has
one. It looks like a small awl, with a sharp but rounded tip, and
is very highly polished. You can make one from an old bur, punch,
or awl, etc. The one is use I purchased as a stipple punch from
GRS and mounted it into a beading tool handle.
The action used is thus: you must fit the stone very accurately,
and tightly. I recommend that you do not undercut the seat, but
use either a round bur or a setting bur. In the case of melle,
say .01 or .02 ct, I put the table flush with the surface of the
gold. You then hold the burnisher a few degrees from parallel
with the gold surface, and pressing the very tip of the burnisher
against the edge of the gold next to the stone (but not touching
the stone), and keeping the tool perpendicular to the edge, go
around the entire edge. I usually clamp the ring in a ring clamp,
and turn the clamp (and ring) while holding the tool somewhat
still (I also move the tool against the motion of the ring).
After making a revolution or two, change the angle of the tool to
closer to 45 degrees and and go around again, then change the
angle to closer to about 60 degrees and go around again, and so
on until the tool is nearly at 90 degrees, and be careful not to
press the burnisher tip against the stone, if possible. By the
time you’re done, you’ll have a bright circle surrounding the
stone, but very close to it. It’s a great technique, and holds
the stone very tightly when done correctly. It’s the technique
that some setters use to set fancy cut diamond melle (1/2 moon,
tapered baguette, square, etc) into patterns like the famous wine
glass shape, into the flat top of gent’s rings. It takes a bit of
practice, but is really extremely simple, and is one of the first
techniques taught to aspiring diamond setters, at least it was
with me. It can take quite a bit of pressure with hard golds, and
the smaller the burnisher tip, the more effect it will have on
the gold.
I hope this description helps, if not, I’ll mail you some
sketches.
Jeffrey
