Attach a sponge lightly saturated with oil to your rolling mill.
Place one sponge above the top roller and one sponge below the
bottom roller. As you use the mill, the sponges will keep the
rollers clean and the oil will keep them from rusting. Before you
use it, turn the rollers on complete turn to clean any dust or
debris that has accumulated on the rollers. You can keep the
sponges in place with binding wire. Just make sure you keep
everything away from the gears.
bottom roller. As you use the rolling mill, the sponges will keep
the rollers clean and the oil will keep them from rusting. You can
keep them in place with binding wire. Just make sure you keep
Brad Simon CMBJ
