To cut short pieces of equal length wire, buy a short section of
copper pipe the approximate diameter that you want the length of the
wires. Then, drill a hole the size of the wire, in one side of the
pipe. If necessary squeeze the pipe slightly oval to make the
distance across the pipe the same as the length of wire you need.
Then, insert the wire through the hole until it hits the pipe on the
other side. Using a saw cut the wire off flush with the side of the
pipe. Repeat the cutting process for the number of wires you need.
Brad Simon CMBJ
