My problem as a gemologist is that if you ask me to describe jade gemologically, I woud not be able to do it.
With all due respect Leonid, you may not be able to describe or
identify jade, but the GIA can, and has. Quite specifically in fact.
Not only that, but demonstrating the ability to identify jade is a
requirement of the Graduate Gemologist Course final exam.
The following quotes concern jadeite jade and are direct quotes from
the “GIA Gem Reference Guide for the GIA Colored Stones and Gem
Identification Courses” book (which is a text book of the Graduate
Gemologist Course), copyright 1995, GIA. There is a similar section
in the book concerning nephrite jade, which has distinctly different
properties but is also described by the GIA as jade.
"JADEITE JADE
Description:
Nature of Material: jadeite (JADE-ite) is one of two minerals
commonly called jade (the other is nephrite); monoclinic crystal
system; chemical composition NaAlSi2O6."
Mineral samples which called jade have different refractive induces,
"Identification:
REFRACTIVE INDEX: 1.666 - 1.680 (+_.008); spot RI, 1.66"
different densities,
“SPECIFIC GRAVITY: 3.34 (+_.06, -.09)”
different spectra,
“ABSORPTION SPECTRA: generally a line at 437 nm; natural green -
sequence of lines at 630, 635, and 690 nm, dyed green - a single
broad band in the area occupied by the three lines in natural green.”
different reaction to UV
"ULTRAVIOLET FLUORESCENCE:
Light green - inert to weak (LW); generally inert (SW)
Light yellow - inert to weak green (LW); generally inert (SW)
White - inert to weak yellow (LW); generally inert (SW)
Light Purple - inert to weak white or weak brownish red (LW);
Some dyed lavender jadeite - moderate to strong orange (LW)
Dark colors - generally inert (LW and SW)"
In addition, these are the recommended tests to help the gemologist
separate jadeite jade from other similar stones;
"KEY SEPARATIONS:
Nephrite - RI, SG, spectrum
Idocrase - RI, spectrum
Hydrogrossular - RI, spectrum, SG
Serpentine - RI, SG, spectrum
Chalcedony - RI, SG, fracture (possibly), spectrum
Maw-sit-sit - appearance, RI
Saussurite - RI, appearance, spectrum, fluorescence"
If something is a gemological entity, than it should be possible to assign to it a specific set of gemological properties, but jade does not have any, and that is my point.
Here are some more specific gemological properties of jadeite jade
as described in the “GIA Gem Reference Guide”;
"Optic Character: AGG (DR)
Birefringence: usually not detectable
Pleochroism: none
Cause of color: green - chromium and/or iron; lavender - iron
(charge transfer); yellow to brown - iron
Polish luster: vitreous to greasy
Fracture: granular to splintery
Luster: dull
Cleavage: not visible due to aggregate structure Identifying
characteristics: shiny reflections from individual crystals on
unpolished backs of larger-grained stones
Crystal Habit: massive"
I am only looking at it as gemological specimen, and as such it does not exist.
If jade does not exist, someone should really tell the GIA so they
can remove it from the Graduate Gemologist course of study and stop
requiring students to identify it consistently without error before
awarding a Graduate Gemologist diploma.
Dave Phelps
