Hello- I am new to enameling and am trying to figure out what kiln
to start with. So I have some questions, having only torch-fired up
to this point.
Is a trivet used so that the piece is supported on its edges
(where there’s no enamel) so one can enamel and counterenamel
simultaneously?
In order to use a small beehive trinket kiln, a trivet would not
fit! How does one fire pieces with enamel on both sides in such a
small kiln?
Any advice is appreciated…
Dana Evans
Also check out the enameling yahoo group at enamelforum. I think you
have to log in to ask a question, but the group is very helpful.
Jamie
Is a trivet used so that the piece is supported on its edges (where
there's no enamel) so one can enamel and counterenamel
simultaneously?
Yes, using a trivet you can counter-enamel at the same time
2In order to use a small beehive trinket kiln, a trivet would not
small kiln?
Use a low profile trivet like the HS-1,2 & 3 shown here:
http://www.thompsonenamel.com/products/tools/firing.htm#trivets
(about halfway down)
Cheers,
Jakob
Hi Dana,
There are many enameling texts available, as well as beginning
enameling classes. Check your local library or Alibris for used
enameling texts and consider enrolling in a class or two.
To answer your initial questions:
The purpose of a trivet is to provide as much structural support as
possible with as little physical contact as possible. Base enamel
and counter enamel are typically not done simultaneously.
As far as a small kiln, they all accommodate some kind of low
trivets. There are a variety of ‘low profile’ trivets available. My
personal choice for teaching is the tabletop Amaco model. It has a
6" diameter chamber, and the depth will accommodate regular trivets.
Gwen Bernecker
http://www.twoolivesstudio.com
