Has anybody ever tried enameling over silver or gold plating ?
Justine
Justine
Don’t bother at the enameling temperature the thin plating will
diffuse into the parent metal.
You will lose the plating.
jesse
Yup
90% of the time I end up with a mess. I find it very unpredictable.
If I didn’t know any better I’d swear that the silver sublimates and
deposits elsewhere. It also seems to crawl around the copper at
will.
I found that I must keep temperatures really low; around 1350 degF.
That in turn presents problems with the flow of the glass.
So why bother? Because the 10% produce interesting and unpredicted
results that have a feel of spontaneity rather than being planned.
David
I used to do enameling over silver-plated steel – Worked quite well.
Margaret
I think the silver plated steel that was used in this instance was
specifically formulated to be enameled. Do you purchase it from an
enamel supplier?
Alana Clearlake
