Karen-
Have you considered using fiber board for kiln shelves? You can use
the board for repeated firings and when they get to looking bad you
just replace it with a new board. Also, you can cut the boards to
whatever size/shape you want. Kaiser-Lee suggests this usage on
their web site at http://www.kaiser-lee-glass-art.com/ You can also
use a regular kiln shelf with thin fiber paper. Some papers are for
one time use, but you’d save a lot of time cleaning off your shelves
and prep time painting on primer.
At Corning Glass, they sift powdered kiln wash onto the shelves
instead of mixing and painting wash. When the firing is complete
they scoop the powder out of the kiln and use it again. (Sifting
will keep impurities from the next firing.) This technique does
leave a texture on the back side of your product, but that might not
be an issue, depending on what your doing. Also, use a mask if you
try this.
Some sources you might want to contact for a regular kiln shelf aRe:
http://www.cdvkiln.com/menuacc.htm
Kiln Shelves, Furniture and Accessories @ SunshineGlass.com Your kiln
manufacturer will more than likely have a web site as well and be
able to give you exactly what you are looking for.
There are a few “brands” of shelf paper and boards I have seen. Here
are a couple types:
FIBERFRAX PAPER & BOARDS are *" thick non-asbestos ceramic fibers,
woven loosely together to form boards that withstand the high
temperatures of fusing and the corrosive effects of molten glass. Use
as a lining to protect the expensive firebrick in your kiln. Also can
be used as a heat proof pad to put on your workbench to set your
Rapid Fire Kiln or slumping molds on. When first fired, Fiberfrax
will turn brown, as the sugar based binder burns off. (Provide
ventilation!)
FIBER PAPER can be used in place of shelf primer. Does not stick to
your project, and gives a slightly textured surface to the back of
your work. 1/8" paper is good for many firings, the 1/32" paper for
a few.
BULLSEYE THINFIRE SHELF PAPER is a heat-resistant light weight
ceramic impregnated paper. ThinFire shelf paper provides excellent
separation between kiln shelf and glass in kiln firing applications
up to 1600�F. Compared to kiln washes, ThinFire reduces shelf
preparation time and improves surface release qualities. Benefits
(when compared to more conventional ceramic fiber materials):
glossier finish on the shelf side of your finished project, less
binder burnout odor, & lighter weight for easier handling and
storage.
Good luck!
