Hi Noel,
First, this is not a cook's torch. The "creme brulee" torches don't
get as hot and, I believe, have fewer adjustments.
Yes, you’re right. The first one I had which died was a cook’s torch
though - it even said so on the front and it came with four creme
brulee ramekins. And although the Bernzomatic was not made as a
cook’s torch, it was indeed in the cookware section of our local
supermarket when my husband went out and bought it for me, so they
were selling it as a cook’s torch. It is quite a bit hotter though
and it did take a short while to get used to the difference in
temperature of the flame. Mind you, although it is hotter, it is not
as adjustable in the lower ranges as my first one. My original
cook’s torch had a dial on the top and that was what you used to turn
the gas on and off and adjust the amount of the fuel being delivered
and hence the flame - so I could turn it right down for tiny jobs but
I can’t do that with the Bernzomatic. I will also note that the
largest jobs I’ve soldered - the pendants I referred to in an earlier
post (3 x 1 inches and 2 x 1.5 inches) - were accomplished with my
original creme brulee cook’s torch with lower temperature flame. So
such jobs are now even more doable with the Bernzomatic.
The regulator is the most expensive item, though they might have
them too-- I never asked.
I already have the regulators, flashback arrestors, hoses, torch,
torch tips, goggles, spanners and everything else I need - just not
the gas! All my available money goes on my monthly silver order as
by the time I can buy some more, I’m almost running out. Or else it
goes on spangly gems that jump out at me saying “buy me - you need
me”! I will make the leap to using my “proper” torch soon, but I
guess because I have the Bernzomatic I just haven’t had a sense of
urgency to do so. Also, I will have to have the gas tanks outside and
have the hoses coming through the open window so during the winter
that wasn’t a very attractive proposition.
I do think that you get used to using what you have available though
and if all your students have available are the hand-held butane
torches, they will learn to cope with them. Then if they go on to
better systems later, they will be all the more talented for coping
with butane torches early on.
BTW, I was fortunate enough to be able to purchase a copy of the
magazine with your bracelet article (courtesy of a very kind Orchid
member Kathy Johnson) and it is truly stunning. Your jewellery is
really unique. I think there are very few people who develop a style
that you just won’t see anywhere else and that is easily
recognisable as your work - a real niche.
Helen
UK
http://www.hillsgems.co.uk
http://www.helensgems.etsy.com
