How to put edge of wire on bracelet
Saw your bracelet out about bigger than you want it first. Then solder the wire on in the correct outline. Then saw the unwanted edge off.
It’s much easier than trying to fit your wire accurately to the finished bracelet.
Irene. G
Thank You
do I wrap wire with another piece around bracelet to hold while soldering?
Sorry I meant a bit bigger, not about bigger, which doesn’t make sense. I didn’t check Spellcheck…curse it
