Hello all you wonderful Orchidians, So many good techniques shared on
this little problem. Excellent point about using white gold posts -
I routinely use them on higher end sterling earrings and note that on
the earring card for those who are nickle sensitive. I also like the
little depression drilled where the post will go - I will use that
tip to help place the post. Great idea - and I think better than a
little dent from striking a nail! I’ll add my own method here which
has virtually eliminated “cold joints”. I put a drop of Batterns
flux on a watchglass. (I’m not sure that Battern’s is absolutely
necessary with use of Prip’s flux, but I do it anyway.) Holding the
post in soldering tweezers, dip the end of the post in the drop of
flux and touch that to the dent on the earring where the post will be
soldered, thereby transferring flux onto earring. Gently heat the
flux so that it dries and turns white on both post end and earring.
Apply Prip’s flux for fire scale prevention. Put pallion of solder
on soldering block, lightly heat post & solder until solder collects
on end of post - it will be a little blob. Heat earring evenly,
watching for Prip’s flux to go syrupy, immediately put soldered end
of post in postion on earring back and heat a bit more until solder
runs to earring. Pickle as usual. Once all the parts are set up, I
can solder posts on several pairs of earrings quickly. Hope this is
helpful. Judy in Kansas where the sun is shining, but the ground is
still frozen in the shade. Snow predicted again!
Judy M. Willingham, R.S.
Extension Associate
221 Call Hall Kansas State Univerisity
Manhattan KS 66506
(785) 532-1213
FAX (785) 532-5681
