I have been reading the posts regarding the use of certain torches
etc. While I will admit that they may be better than nothing at all,
they are all going to lead to the following type of problem which is
unnecessary. Bev Bockman editor of the Northwest Federation of
Mineralogical Societies’ newsletter wrote me. “I had a terrible time
finding the right torch for my fabricating work-gave away one, sold
one and finally got a torch that seems good.”
The problem is with some of those solutions, so-called, is what they
can not do. This is not being mentioned. What is worse, is they will
subject people to the same problem above. Miss Bockman is not, was
not, a novice and had no need to “learn” until she got experience, as
I was told in looking for a solution. It’s quite easy to loose a
sense of humor, quickly; it’s not funny or smart. Sadly I see this
repeated. Why? There are some other problems as well.
LP gas storage in a residence (USA)- The NFPA regulation has been
adopted by all 50 states is that you can have a 2 1/2 lb. (Coleman
type) container, and no more than 2 for a 5 lb. total in a residence,
maximum, this is now law. This includes a structure attached to that
residence, such as a garage. Some districts and states have adopted
an earlier recommendation as their code, that is a 1-lb. canister and
no more than two. This means that larger LP tanks are not legal even
to store in a residence, sorry.
Acetylene is widely banned. Where it is not insurance can be a
problem. Call or email your fire department. If you have a studio
that is not your residence the same applies for any gas storage, see
what the code is. You may also want to ask your insurance company, it
may void your policy. That is you may find you do not have a policy
(on anything due to that acetylene tank or of course any non-code gas
storage). Even if in compliance the insurance carrier may drop or
refuse coverage, or want more $$.
If you are renter a regular oxygen tank may be out of the question.
The disposable canister last (on a Little Torch) 15-25 depending on
setting, at about $10 a pop. I do not see that as practical,
especially on silver.
There are ways out of this. The following is edited. "I am a list
member (different list) and have dealt with this flammable gas
storage, in the following manner. I am very respectful of safety
procedures and the need to meet fire codes. This is what I have done
in my home shop. I have an Oxygen refillable container. 40 cu ft. (M)
I use a disposable 16 0z propane cylinder. (Smith Little Torch) Do
not waste your time on the disposable oxygen tanks . - A total
waste of money - Not economical at all to use. If you wish to avoid
problems at all . simply sit the entire soldering set up outside
when you are not using it. Put it inside a secured, lockable, vented
cabinet OUTSIDE. Another used a licensed contractor for some
plumbing; tanks were outside. Another got hold of a used oxygen
generator for $100 and uses a propane canister. Those ideas are out
if you rent and new oxygen generators are quite expensive. Water
torches, another option, cost $ and are not the best choice for
everything.
I could not use acetylene, period and was limited to one pound of
gas. Furthermore I could not use a regular oxygen tank. I wrote to
the IGS about the feasibility of using converted acetylene equipment.
The answer was that I should rethink that. What you need is high heat
and fine control. Jewelers usually use oxygen and propane or
acetylene to do in seconds what will take minutes.
The converted equipment would work, with a large downside. The usual
air/propane torch is an acetylene torch with different tips allowing
it to burn propane. They are not even close to a match of their
unconverted counterparts. I had almost given up on a good solution.
I found a solution to my problem in the Precision LP Gas Torch. I
prefer it to air/acetylene for silver, had been using the clubs
torches; its real strength is in the fine work it is capable of. It
is a goldsmith’s torch after all, and unlike claims made for some
things this is no joke. The cooler flame is an advantage on silver.
It will not alloy palladium white gold, but will cast several
premixed palladium white gold casting grains. It will alloy any
standard gold or silver alloy. As for casting at about 400 Kpa, tests
were carried out, casting 90 grams of sterling. The agent’s regulator
goes only to 450 Kpa and have alloyed and cast 100 grams sterling,
ONE STEP. As for commercial casting grain (and/or scrap) I do not
know. I admit a Smith handi-heat will cast more. But again this wins
for detail work, good for filigree or the like, very nice for silver
jewelry construction also. A 0-60 Psi regulator on a disposable
canister gives you about 414 Kpa, which is not needed for just
soldering, but is still more than enough for alloying and casting as
said above. It solved my problem and I am very happy with it. This is
a fine product; I have no financial interest.
For on that torch, see
http://www.apecs.com.au/guild/lpgas.htm also for all interested see
http://www.apecs.com.au they have an excellent article on alloying in
the small shop.
It is painful to notice a repeat of various things I have seen in
print the last few days, pistol grip plumber’s torches, pencil
torches, and the like. You are in for disappointment if you get one
of those. You are much better off with that Shark torch I mentioned.
See Ebay $59 or Kent’s tools. Not my first choice, but a hands-down
winner over the likes of those. They will just not get it. Do not
delude yourself about it, or others.
As for air/acetylene torches, I assume that if this is your choice
you do want a good price on it. See these links for other torches as
well, always shop around (PS noticed some inflation since last I
looked) Prest-o-lite torch http://www.jsritter.com/tools/torch2.htm
$137.95 complete (tank extra, usually best got locally). Smith etc.
(Smith Handi-heat # NE835a complete kit $178.00, minus tank)
http://www.jandrweldingsupply.com - This last would be the first
place I would look, unfortunately the web page is under
reconstruction, you may want to wait, seriously
http://www.pacificwelding.com -
Lastly do not be shy about calling local welding suppliers on the
torch you may want. There are some exceptions but jeweler suppliers
usually do not have as good price as welding supply. (They sell so
few by comparison.) Always keep an open mind, become informed, and
most importantly always shop around when a decision is made, dollars
saved are the same as dollars earned.
