Displayers
I am hoping that some Orchidian knows a source for a specific type of
ring displayer which I used to use, but can no longer locate in any
of the myriad catalogs which I possess.
It is basically a ‘letter C-shaped’ piece of slightly springy plastic
which fits inside a ring shank. Sticking out from the outside of the
curve is a short pin (slightly larger than the size of a push-pin or
thumbtack.)
This allows one to display rings from most anything.
Any ideas?
Thank you,
David Barzilay, Lord of the Rings
Hello, I subscribe to Orchid Digest and mostly lurk. But I noticed
your question and in the 2001-2002 Catalog for Fire Mountain Gems, I
noticed some flexible plastic ring displayer that might work for
you.
The item No. is 10-1278PK and they are sold in packages of 6 for
$3.29 with better discounts as you buy more packages.
The phone No. is 1.800.355.2137 and there web address is:
www.firemountain gems.com. You can order through their website,
their catalog is also online.
Hope this helps.
Debra A. Paolo
Blackbird Pond Designs
