John, these core drills, are they ones like a petrologist would use. Do they drill a "circle" into the stone creating a column [which would then be popped out]?
G’day Colleen; That’s exactly right, only the bigger cores
aren’t all that easy to pop out. Some folk make things like
vases that way - even wide mouth vessels by drilling several
cores, then cleaning up after - pretty laborious. Some find
drilling concentric holes to the same depth provides easier
break-out. And for drilling I still prefer to have the piece of
hard material just under water in a tray, and the diamond
rotating around 800 - 1000 rpm; much faster and you need a
wetsuit. I have a sturdy plastic and cloth backed mortuary type
apron and still get wet on occasion. –
/ / Johnb@ts.co.nz
/ /__|\
(_______) In sunny temperate Mapua NZ - clocks go back Sunday;
Done roamin’ in the gloamin’ now autumn’s here…
