Hi,
I’m trying to dap some old lithographed tins. Unforutnately, the
image on the tin keeps flaking off. I tried lining my metal dapping
block with suede and coating the tin with a couple coats of Krylon
acrylic clear coat. I also tried several different tins. No luck.
Does anyone have any suggestion on how to preserve the images on the
tin and still achieve a dome?
Thanks,
Beth
I would try a hydraulic press.
Elaine
Elaine Luther
http://www.CreativeTextureTools.com ™
Hard to Find Tools for Metal Clay
the tin and still achieve a dome?
Can’t promise it would work, but I’d try a hydraulic press. Cut a
circle out of plexiglas or masonite to use as a die.
Noel
I'm trying to dap some old lithographed tins. Unforutnately, the
I don’t think that you can. You are stretching the metal when you
dome it and the paint can not stretch at the same rate.
marilyn
Another way to go about it would be to scan the images and apply it
to another metal, and hydraulic press that.
Maybe Lazertran would work.
http://www.lazertran.com
Elaine
Elaine Luther
