An accurate way to cut ring stock is to use jewelers saw and a tubing
cutting jig. You can set the length for the size of ring that you want
and do repetitive cuts. Rio Grand has them on page 204 of the current
catalog.
The ends will be square but not perfectly smooth. If you are looking
for the best joint you will want to file the end after cutting. To do
this easily, I have made a jig from a bench pin and 18 gauge brass
sheet.
I have enclosed a GIF file with pictures and notes of the jig that I
designed. I’m hoping that Hanuman will put it up on the site.
Thank you Hanuman for this wonderful service.
Timothy A. Hansen
TAH Handcrafted Jewelry
P.M.B. 131, 305 N. Second Ave.
Upland, California 91786-6028
U.S.A.
E-Mail: @Timothy_A_Hansen
Web-Site: www.home.earthlink.net/~tahhandcraft
