Here is some about the Koil Kutter made by David Arens I
picked up over at Wet Canvas. Hope this helps, Mona
Dave Arens, Tucson
Here’s the tool list.
Gemstones Etc.
3649 N. Pellegrino Drive
Tucson AZ 85749
520-749-2413
E-mail:gemstonesetc@gci-net.com
Koil Kutter $69.95
A device to easily and safely cut coils of wire into rings. The
device attaches to any 1 in (25 mm) diameter flexshaft hand piece,
e.g. # 30 Foredom hand piece, or motor tool, e.g. Dremel (or similar)
or Proxxon. The device consists of a replaceable cutter blade mounted
on an arbor, a cutter guide, a coil holder, wrench & instructions.
Koil Mandrels $39.95
A set of 23 mandrels, 2-13 mm in 0.5 mm steps, for winding coils.
All mandrels have one end slotted for holding wire and will fit in a
3/8 in (9.5 mm) chuck.
Koil Winder $24.95
A manual winder that can be clamped to a work surface. It will
accommodate all the mandrels in the Koil Mandrel set.
Link Stretching Pliers $14.95
A pliers with an adjustable stop for stretching round, fused or
soldered rings into uniform length oblong rings. As a result of the
stretching all joints are also tested.
Chain Draw Plate $12.95
A corian draw plate with holes from 3-13 mm, used to draw handmade
chain to a uniform size.
Replacement Kutter Blade $9.95
1.25 inch diameter, 114 tooth high speed steel blade.
Solder Aid $3.50
Finger & hand grip for aiding squeezing solder from 3/4 in. diameter
(approx.) paste solder syringes. Includes clean out wires for 16 and
20 gauge needles.
Soldering Stand $3.00
A 4 =BD inch high metal stand to support link assemblies & chains
while soldering.
