But if it were contained, say in a heavy iron container, so that
hammering would be forcing it into a smaller area, then wouldn't
it become denser? Or can't that be done? Or if you had a thick
rod, again contained in some way, and you hammer it at one point,
wouldn't that point be denser?
No doubt Jim, the wizard, will post to this, too. Not just Janet but
much of this thread misunderstands something fundamental, which
isthe very nature of matter. I won’t get very technical largely
because I forget a lot of that stuff, in detail. Look at it from the
other perspective - that of atoms and molecules, which make up all
matter. They are subject to “the four forces” which is where we
won’t go because that’s a whole physics lesson. Suffice it to say
that atoms are attracted to each other but only in certain ways and
only so much. They do that because of the electromagnetic force on a
molecular level. What that means to this thread is that atoms - we
don’t need to say molecules because all metals are “monatomic” - an
atom and a molecule are the same thing in the case of metals - will
naturally pack together, that close, no closer, no farther,
according to the attraction of the EM force. The only thing that
will change that for a given material is temperature.
What that means is that all matter is un-compressable by normal,
physical means. That means solids and liquids. In gasses the atoms
are far apart and they CAN be pushed closer together. When it is
compressed to the point where the atoms come as close as they can
come, the compression will stop and the gas will liquify. Liquids
are not compressable - as another said, that’s the root fact of
hydraulics.
So, what one is saying when the thought arises that “metals can be
compressed and the density will change” is that one can overcome the
fundamentalEM forces between atoms with a hammer. That is just not
ever going to happen, not even a little bit. Those atoms are
arranged in their natural order and nothing purely physical will
change that. In metals (and other substances) the atoms arrange
themselves in symmetrical, crystalline structures, which is the
grain that Jim has been talking about all along. But those atoms
still are only so near, and so far apart andthat is a fundamental
fact of particle physics.
Now, sure, if you take all of this to the atomic level and the
universe and all, then this can be changed. Nuclear reactors,
hydrogen bombs, the center of the sun, black holes. Under those
conditions matter becomes plasma, which is anentirely different
animal and discussion. But hitting a rod with a hammer? Not ever,
The material is in it’s natural atomic state and you just can’t
change that, that way.
