Correct filing angle off a large claw setting
Quick tip: What is the correct filing angle to finish off a large
claw diamond setting?
If you are using a Triangular file of either #2 or a #4 cut 20 cm in
length you will notice that either side has a 45 degree angle built
in. Simple? But why at this angle?..
Read more:
https://www.ganoksin.com/gnkurl/ep7ztj
bloggers!
http://ganoksin.com/blog
If you have been considering your own Blog, but haven’t yet, the
I’m a bit confused. Do you mean a 3-square file? Because 3-square
files are equilateral triangles in cross section, so all three edges
are a 60 degree angle. A file with 45 degree edges sounds more like a
barrette file.
Elliot
YES, I stand corrected, you are totally right. This should have read
60 degree” angles! My humblest appologies for this oversight:
Gerry!
