Hello all,
I am just getting started making jewelry and I am about to make the
torch plunge. I am a bit confused when it comes to torch tips and
regulators and I was wondering if all you out there could help clear
up some of the issues i have been having.
First, I would like to use a prest-o-lite torch that originally was
intended for acetylene with either propane or MAPP, can I do this?
Second, can I use one of those pre-set regulators for disposable
canisters with a prest-o-lite torch? I will have to replace the hose
that comes with the acetylene torch with LP hose.
Third, will I be able to cast small pieces (one off sand casting)
using propane?
I live in rental property and my shop is a small shared space. If I
had a bigger shop I would go with oxy/acetylene.
Thank you for your help
Kenneth
