Hi Folks,
Okay, some of you have compressors for your GraverMaxes, some
have them for bead blasters. Does anyone (can you) use the same
compressor for both? What else can you use an air compressor
for in the studio?
The bead blaster available from Reactive Metals calls for a 2cfm
@ 80-90 psi. That sounds like low flow at high pressure to me
(but I am ignorant of such things). Is that normal? Is that a
comparable compressor to what a GraverMax would use?
Rick, is this in line with the Badger Silent II you have? I
suppose you could also use it for airbrushing, if you were so
inclined?
Dave
Dave Sebaste
Sebaste Studio
Charlotte, NC (USA)
Note From Ganoksin Staff:
Looking for an air compressor for your jewelry projects? We recommend:
- Reading our guide to the best air compressors for jewelry work here
- Searching for more discussions about air compressors here on the Orchid forum
