Is there any way of colouring precious metal clay - either silver
or gold PMC? I suppose that simply mixing silver and gold PMC
wouldn’t work, because that just seems too obvious! But could you
mix in something like powdered niello? I would like to achieve a
kind of “mokume gane” effect, by kneading differently-coloured PMC
mixtures together, but I don’t know of any way of achieving a colour.
Has anyone tried something like this?
-Michael.
wouldn't work, because that just seems too obvious! But could you
kind of "mokume gane" effect, by kneading differently-coloured PMC
mixtures together, but I don't know of any way of achieving a
colour.
Try mixing dry enamel with the PMC, about 50/50, then combine. If
you use too much enamel it will run some. Not all enamels fire true
to color. Blues and greens usually work, red does not. I have not
tried this with PMC+ or PMC3, but it will probably work with those
too.
Cathy
too.
I’ve done this with PMC+, and it works. I feel that the ratio is
less than 50/50. Serious enamelists are shocked by the color
changes the enamels go through.
Elaine Luther
Chicago area, Illinois, USA
Studio 925; established 1992
@E_Luther
Please identify the units of the 50/50 mix (weight or volume - big
difference) and Elaine, when you say “less than 50/50” I assume that
you mean less of the enamel and more of the PMC. Right? Tom
big difference) and Elaine, when you say "less than 50/50" I assume
that you mean less of the enamel and more of the PMC. Right? Tom
I go by volume, nothing scientific, but by sight. It is hard to
estimate equality with a ball of PMC and a pile of enamel. You will
also need to add water drop by drop to get the right consistency.
Cathy
