Colorit Process
Hello,
I am interested in more detailed instructions that those found in
Gesswein webpage about the COLORiT process (I have made copy & paste
below).
Does somebody know a link to a pdf file o similar, or want to
explain the process a bit more?
Best regards,
Salvador Alcaraz
The COLORiT Process
Both a mechanical bond and a chemical bond are required to
ensure durability and colorfastness. Inlaid areas must be
undercut, and proper application and curing instructions must
be followed. COLORiT is easy to apply and dries in minutes
under the special curing light. From cleaning to final curing,
the entire process usually takes no longer than 30 minutes;
curing comprises roughly half that time and requires only
minor attention.
