Materials: Printed steel, hardware snap ring; varied beads, sterling wire and chain
Dimensions: 4 3/4 inches in length from bale to tip of charms; 1 7/8 inch wide
Hydraulic press formed center, sandwiched between two stacked/decked layers, tubing for deck spacers;silver headpin rivets; varied semi-precious, silver and vintage beads, and steel dangles on sterling wire.
Photo credit: Pam Wittfeld
Lisa Wood
Lisa's Designs
Gold Coast, Queensland. Australia
I consider my jewellery to be miniature sculptures, which celebrate colour and beauty and move and interact with their wearer. They are intended to move constantly, changing shape with the movement; translucent and emitting the ambient light, adding to the interplay of movement and kinesthetics.
These works are created in plique a jour enamel, (like miniature stained glass) to allow the light to penetrate and flow through. The enamel is wet "painted" individually into silver cells and fired. The process is repeated and then stoned back and re-fired. They are extremely delicate (because there is no metal backing) and can crack and break at any point in the process.
I am a trained visual artist, living and working in the rainforest in Queensland, from where I draw my inspiration for my art
http://www.ganoksin.com/exhibition/var/albums/Changing-Hues/Tin%20Color%20Pencil%20Necklace.jpg
