I want to share a channel repair that was completed recently for any who may need to do this. The customer wanted the out side channels rebuilt. It wasn’t necessary but hey I’m just the jeweler. I took some 18ga round wire and rolled out
it to about .33 mm thick. Then the strap was formed to grab the outside edges of the ring which was the PUK welded out outside edge to hold in place for soldering making sure center made contact with ring. Then soldered center of strap, after cooling and pickle then hammered down to make contact along entire length and then flowed solder along entire width. Then just clean up. Hope my pics are helpful.Franz
