Worth 1 cent . . . not two;
Started with Vacuum … as an amateur . . I continue to consider myself as
an amateur probably due to casting techniques and as one would, have tried
many, many ideas, methods, suggestions to very little added success. . .
most local "business professionals, casting for as a corporations have
suggested that,
" Detail is lost with vacuum!" . . . spelled ‘Quality’
" Readability, forgiveness, in method is lost with vacuum!"
… GET RID OF IT!!! …
THAT’S WHY I LOOKING FOR A CENTRIFUGAL!
C U R R E N T P R O B L E M S WITH ‘MMYY’ VACUUM PROCESS!
Instruction which came with the unit(most popular brands carry basically the
same ‘blue’ , ‘multi buck unit’)
Equipment documentation suggest that the silicon pad scorches at 900
degrees. Investment break down between 1250 and 1325 . .considering the
problem presented by porosity at higher temp, in that silver melts at
16++/17++ depending on quality . . there is a ingrained problem…
( And I’ve had/have them all . . requires more control than the less
auto-equipment.
Absolute prefect surface is required relative to the bottom of the
flask being cast… drop an empty flask and you can either through
it away or file the bottom for an hour to remove the dent… a
break in the vacuum!
Slightest 'scorch/ring in the pad( $20.00 A pop!) will prevent the
vacuum from taking Place! . . . NOW WHAT ABOUT THE MOLTEN SILVER(Watch
that temp!), cylinder getting cold( greater difference in silver temp
and cylinder Temp spelled porosity!.
Vacuum allows doubt as to success with pour . . Vacuum often doesn't
come up and you feel you must pour because of the variations in temp! .
. sometimes it works … sometimes it doesn’t! . . . as Processes go
this just doesn’t make it . . according to most pros I’ve met … and
this amateurs . . unless someone out there can help!! Got to give it
up!
ETC., Etc. . . If you have the answers .... I'm listening!
HEADED FOR CENTRIFUGAL IN TAMPA!
(SOMEONE, . . . AN A MATURE, TELL ME THE PROBLEMS WITH CENTRIFUGAL…
PLEASE NOT YOUR SUCCESSES!)
THANKS,
JIM
