User srossing is not defined
Original text follows
Received: from proteus.imagiware.com by HC.huntsman.com (SMTPLINK V2.11)
; Fri, 06 Dec 96 06:26:12 cen
Return-Path: owner-orchid@proteus.imagiware.com
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id DAA22736 for orchid-outgoing; Fri, 6 Dec 1996 03:39:11 -0600
X-Authentication-Warning: proteus.imagiware.com: majordom set sender to owner-orchid using -f
Received: from mail.phoenix.net (mail.phoenix.net [199.3.232.20]) by proteus.imagiware.com (8.7.6/8.7.3) with SMTP id DAA22731 for orchid@ganoksin.com; Fri, 6 Dec 1996 03:39:09 -0600
Received: from HC.huntsman.com (hc.huntsman.com [207.43.29.211]) by mail.phoenix.net (8.6.12/8.6.12) with SMTP id DAA24341 for orchid@ganoksin.com; Fri, 6 Dec 1996 03:39:26 -0600
Received: from ccMail by HC.huntsman.com (SMTPLINK V2.11)
id 9611068498.AA849872364; Fri, 06 Dec 96 03:39:24 cenDate: Fri, 06 Dec 96 03:39:24 cen
Message-Id: 9611068498.AA849872364@HC.huntsman.com
To: orchid@ganoksin.com
Subject: ccMail SMTPLINK Undeliverable Message
Sender: owner-orchid@proteus.imagiware.com
Precedence: bulk
Reply-To: orchid@ganoksin.com
; Fri, 06 Dec 96 03:39:14 cen
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id BAA18825 for orchid-outgoing; Fri, 6 Dec 1996 01:54:50 -0600
Received: from mail.phoenix.net (mail.phoenix.net [199.3.232.20]) by proteus.imagiware.com (8.7.6/8.7.3) with SMTP id BAA18821 for orchid@ganoksin.com; Fri, 6 Dec 1996 01:54:48 -0600
Received: from HC.huntsman.com (hc.huntsman.com [207.43.29.211]) by mail.phoenix.net (8.6.12/8.6.12) with SMTP id BAA20890 for orchid@ganoksin.com; Fri, 6 Dec 1996 01:55:05 -0600
id 9611068498.AA849866103; Fri, 06 Dec 96 01:55:03 cen
Date: Fri, 06 Dec 96 01:55:03 cen
Message-Id: 9611068498.AA849866103@HC.huntsman.com
Precedence: bulk
; Fri, 06 Dec 96 01:54:53 cen
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id AAA11990 for orchid-outgoing; Fri, 6 Dec 1996 00:07:11 -0600
Received: from mail.phoenix.net (mail.phoenix.net [199.3.232.20]) by proteus.imagiware.com (8.7.6/8.7.3) with SMTP id AAA11984 for orchid@ganoksin.com; Fri, 6 Dec 1996 00:07:10 -0600
Received: from HC.huntsman.com (hc.huntsman.com [207.43.29.211]) by mail.phoenix.net (8.6.12/8.6.12) with SMTP id AAA15922 for orchid@ganoksin.com; Fri, 6 Dec 1996 00:07:24 -0600
id 9611068498.AA849859638; Fri, 06 Dec 96 00:07:18 cen
Date: Fri, 06 Dec 96 00:07:18 cen
Message-Id: 9611068498.AA849859638@HC.huntsman.com
Precedence: bulk
; Fri, 06 Dec 96 00:07:05 cen
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id WAA05803 for orchid-outgoing; Thu, 5 Dec 1996 22:48:14 -0600
Received: from ansel.intersource.com (ansel.intersource.com [206.97.64.2]) by proteus.imagiware.com (8.7.6/8.7.3) with ESMTP id WAA05798 for orchid@ganoksin.com; Thu, 5 Dec 1996 22:48:12 -0600
Received: from 206.97.78.15 (pm1-13.conn.kiva.net [206.97.78.15]) by ansel.intersource.com (8.8.3/8.6.10) with SMTP id XAA26168; Thu, 5 Dec 1996 23:49:40 -0500
Message-ID: 32A750CC.682A@kiva.net
Date: Thu, 05 Dec 1996 22:46:37 +0000
X-Mailer: Mozilla 2.0 (Macintosh; U; PPC)
MIME-Version: 1.0
Subject: Re: flawless chains
References: <v03007803aecaa03a7af4@[206.15.83.25]>
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Precedence: bulk
If the wire is wrapped around a wood dowel and sawn with a fine blade, a
ring of wire can than be opened side ways. Any marks are then on the
outside of the ring where they can be more easily removed. There are
various plies for sale that come with heavy duty plastic on the jaws. I’m
sure that this would be more durable than a thin coating of plastic dip. Of
course you could get creative with the dip and make patterns etc.
Marilyn Smith
