it’s also the specific version of that design style that requires
the traditional techniques of filligree fabrication, and here it
describes that specific technique as well as the resulting style.
Yeah, but what are you going to call a piece of jewelry with fine
wires making a pattern than has been cast?
Your choice, Richard. As I suggested, the word filigree can apply to
the design style, regardless of how it was made. So if you want to
call your fine wire design filigree, go ahead, if that seems to best
describe it. Or, choose another term. lacework, wire weave, whatever
suits your fancy and fits the piece. There are some style names that
specify a particular method of production, and perhaps once, the word
filigree did too. But these days, in common usage at least, it’s no
longer specific to just the manual fabrication methods with fine
wires. You can try and be a purist, of course, and buck the trends.
This, I’ve noted as I’ve gotten older, seems common with my
generation by now, and my parents and grandparents generations before
us, in trying to resist the usual modifications to and evolution of
language that younger generations always seem to add. In general,
despite the outrage expressed by purist older generations regarding
terrible usage of language by the young, and no doubt shameful
ignorance of tradition… well, the language and it’s use seems to
evolve anyway. Fight it, or learn it and use it, going with the flow.
Your choice.
How about this choice: Consider all that Edwardian era and art deco
era stamped white gold and stamped or hand pierced jewelry that
consists of lots and lots of delicate pierced (either by a die, or by
hand) lacework, often decorated on the thin lines with lots of
millegrain work. The end result is not all that different from the
patterns on the individual wires of hand made classic filigree, and
is clearly in the same design category as classic filigree, if one
ignores the usually more geometric deco styles rather than the
somewhat paisley sorts of patterns of classic fabricated filigree.
I’ve seen such pieces more than a few times, described with the word
filigree. Being fairly knowledgeable about jewelry, I find myself
then fully understanding what is meant. Is the word wrong? it conveys
to me, at least, the correct Should I be angry that the
word might not be technically correct? Or just happy for the
Like I said, Call it whatever works best for you, Richard. If you’re
more comfortable adding the word “cast”, or other descriptors to the
word filigree, or using other words entirely, be my guest. I’m not a
member of the grammar police. Just a user of the language. If your
description tells me what the thing looks like and is, I’m happy. if
it deceives me into believing the piece is something other than what
it is, I’m not. Take it from there.
Peter Rowe
