Hey Janet- Good question! Here is a solution that you will like, as
well as your shop (the bottom line)… First off- flouescent bulbs
have come a long way since the days of flicker-start… but the
color shift is something to be wary of…
Our naked eye “tunes” the colors to what we know should be… but the
refractive properties of certain stones and certain metals arent as
forgiving… especially if there is any photography involved…
Incandescant sheds a yellow tint, UV/Flourescent (yes, even the
"Full-spectrum" high dollar ones are this way) light bars shed a
blue-green shifted light.
Halogen bulbs are a bit more to the visible wavelength, but if you
want to be right on for spectrum- use Xenon bulbs. Go to your local
Lowes or Home Depot and take a couple of paint samples from the paint
aisle (its OK- they wont yell)… get 2 paint cards of the same color
white, 2 of the same color pastel (any color- but pinks and soft
ivory are more dramatic) and 2 solid colors in earthtones. Go to the
Flourescent/Undercabinets aisle and lay one card of each under
different lights… (theres also a “lightbox” with a
Sunlight/UV/Incandescent switch in most paint departments- same
experiment- less hacking throught the store…) You will see a
dramatic difference!
This is commonly what happens when you get paint home and “It just
doesnt look the same” after you put it on the walls- its the light!
Now- another test is to take a picture with regular 35mm film (its
corrected for Sunlight), you will get a sickly green to the persons
face you are shooting under UV, and an almost campfire glow in
incandescent (regular lightbulb) light… Which in synopsis is
basically- get a color shifted light if you are worried about truth
in stone reflection and showcasing- but the usual bulb is about 20 W
and uses about 5-7 cents of electricity EACH BULB per day! (statistic
from Daily Press 9-25 edition)
OK… well… info overload time kiddies! HA! If you want a Greener
wallet and a greener Eco- concious outlook (Sidebar note: This
actually has helped sales at some shows as "Energy Star and
Eco-Friendly are big Buzz words- laugh- but its true! I have sales
from a local eco club that liked the eco friendly approach- Vinegar
pickle at the show, reclaimed pumice and sawdust for buffing
medium… you can take it a long way)
Try looking into the new breed of LED lights! Low draw electrical
(less than 2 cents for a bank of 5), and high blue-white light that
is pleasing to the naked eye. High lustre and reflectivity as well- a
blue-white light makes pearls POP… and I could honestly not believe
the change in my few (OK-2… Im still a beginner and dont have a
large stock) diamond pieces!
-As the LED is not a filament style bulb- it produces no heat (less
than 1 degree in most settings- its a solid state emitting diode- no
excess thermal energy to burn your arm as you reach past the
bulb…)
-The LED also has a running life of over 4000 hours- no more
changing bulbs! Available in spotlights and “bar” light styles- its
cool to use and can even be run from a 12 Volt source- low voltage =
less energy drain/no more bought bulbs = more money in your bottom
line.
-For those reading and scoff at the please note- I have
no vested interest in the company I am recommending- but I do have a
vested interest in my environment, and in my profits- Im the guy who
wants to know why is it saving me $$$ as well as what is the other
product NOT doing to save me $$$ BEFORE I switch… The LED meets
the 55 watt/lumen capacity required for light sources, and produces
no radiant thermal energy- this also (if youre big on logistics and
operations in your shop) saves on A/C and wasted energy if youre
paying the rent!
-I switched my house-shop over and no longer sweat in the shop from
a combined 300 watts of worklamp over my shoulder, and have begun
switching my showcases as well- Case in point- I switched one
showcase out 2 years ago- the one beside it- still has Halogen track
lighting spots- I have been through 6 Halogen bulbs in a year- the
LED case gets more compliments, and has yielded better photo results
as well (nothing posted- I would have to scan and Im not there
yet)…
-There is a company that has an excellent website and customer
service support for this type of light. It is the company I use- but
you can find a retailer of your choice anywhere. But I sincerely
hope this is helpful and in overall worth- the
investment is a choice- but the savings are manfested in a variety
of ways! The company info: Cyberlux- www.cyberlux.com Located in
Research Triangle Park, Durham, NC TELE:(919) 474-9700
Love this forum- from a beginner to the rest of my peers- I am
finally glad to have returned a tidbit of info to the collective- I
have drawn so much from it in so many ways! Fellowship and
Knowledge!
Kerri Duncan- SilverForgeStudio
Norfolk, VA
