hello. Can anybody recommend some good Canadian jewellery tool
suppliers?
also, i am going to use a natural gas/oxygen torch system and i
can only afford one torch so it has to do melting as well as
small soddering stuff. what do you recommend?
what do you think of the hoke torch?
durston rolling mills?
thanks.
In regards to Tool Dealers:
Gesswein Canada 1-416-675-9171
I Shor Canada 1-800-268-1990
Both are nice companies to do business with.
Andy
I’ve used a Hoke for the bulk of my career. I currently use
natural gas and oxygen. I work on gold and platinum and do gold
casting with it. If I pressed it I am sure that I could cast up
to an ounce of platinum at a time. Good luck Bruce
Bruce D. Holmgrain
Maryland’s first JA certified Master Bench Jeweler
http://www.goldwerx.com
manmountaindense@goldwerx.com
Hi,Hoke are OK, but they can develope bad seats and leak gas or
oxygen sometimes. Meco are more reliable and have have a larger
assortment of tips. Jim @Jim_Zimmerman1
I have noticed that the valves on Hoke torches tend to wander
thus changing the flame.
Try this test
Light your Hoke torch. Push in on the valve with your thumb and
then pull it out. You will be amaized at how much play there is.
I have also used the Meco torch and find it to be a much better
torch. I also like the Smith Little Torch. It has the most tip
options, it’s the torch that I use now.
Timothy A. Hansen
@Timothy_A_Hansen
http://www.home.earthlink.net/~tahhandcraft
I live in Vancouver Canada, you might try
Lacy West Supplies
1B 736 Granville Street
Vancouver B.C.
V6Z 1K9
(604)-669-5229
They also have a web site I believe http://www.lacywest.ca ???
Habsons
Page and Wilson
If you are interested I will locate the addresses and phone numbers.
Tamara
