Rhino offers tremendous flexibility for design.
Matrix is a great program, and a real time saver. The guys at
GemVision have done a LOT of work to write scripts in Rhino that
automate certain functions. For more complex pieces that can’t be
done within Matrix, one simply calls the Rhino functions right within
Matrix, as it’s built on top of Rhino.
ArtCam includes great CAM , does great heightfield surfacing of
domed and angled surfaces, but it weak in the modeling area. It’s a
different type of program than Rhino.
I haven’t seen any impressive work with JewelCad, but that really
doesn’t mean anything other than I haven’t seen any impressive
work…
Jewelers also use several other programs. Some are CAD exclusive,
and some have both CAD and CAM. I understand the newest version of
Type3 is killer… Cimagraphi is a popular program. TrueSpace is used
for jewelry too, as is SolidWorks, etc…
One really has to look at the type of jewelry they want to produce
and purchase the program that can create it best.
2 - Or does each have a specific application that it is best
at?
Yes, all are quite different.
Rhino is NURBS surface modeling at its best. I use it extensively
and constantly to produce complex jewelry models. Matrix, as
mentioned above, automates many complex routines to save you time.
ArtCam is a heightfield modeler and CAM program or great
capability. It uses gradients invisibly to produce raised 3D surfaces
from outlines, and has some basic other modeling capabilities. I
haven’t seen the latest release, but I understand it’s improved
considerably. It’s quite capable in its own way, and I would love to
own it, but it’s quite expensive at about $7000.
I can’t say much about JewelCad as I don’t know anyone who uses it,
nor have I seen any impressive work from it, which doesn’t mean much
3 -What has the support been like from each of these software
developers?
Rhino support A+ Matrix support A+ I don’t know about the others…
4 - In terms of producing an actual model, can a 4 axis
milling machine produce similar pieces to other RP machines such as
SolidScape's T66 or other types of RP machines?
Depends on the model, and on the capability of the CAM program to
use 5 axis indexing for 4th axis milling. Sorry for the complexity. 4
axis milling has several levels of sophistication, and only the most
expensive CAM programs make full use of the 4th axis milling machine
capabilities. Just the same, 3D printing can produce most any
pattern, and 4th axis milling just simply cannot. The problem is the
cutting tool geometry, and accessibility of the area to be cut.
5 - Has anyone had any experience with Gemvision's Revo540
milling machine?
I haven’t physically used on, but I can tell you it’s probably one
of the very finest 4 axis desktop machines available.
6 - Those with both a CAD and CAM system in-house, has your
work been primarily for your own use, or do you operate as a
service bureau?
My own use, and an occasional job for jewelry stores.
7 - Those that send CAD files to a service bureau, do you have
long lead times? Is there a shortage of service bureaus?
Depends on the service bureau, period. You can get two day service,
or 2 month service, depending on who you use.
No problem, good luck!
Jeffrey Everett
