I, too, love making chains. I have found that care in cutting the
links makes a huge difference in rough edges. If it’s sterling, I
use my Jump Ringer to cut them and make sure the blade is sharp. That
way I have very little (if any) roughness to start with. Then I
tumble the finished chain (rotary, with steel shot & burnishing
compound) to get rid of remaining edges.
I don’t solder these types of chains (Byzantine, Foxtail, etc)
unless the links are large for the weave & so likely to catch & pull
apart. For example, I make a tapered version of the Foxtail chain and
solder all the links in the larger middle section. By Foxtail, I am
referring to the weave that is like Byzantine but is a pattern of 4
links instead of 6. It’s a very neat square pattern. There is a
picture of one on my website.
For soldering links, there’s a trick to keeping solder from jumping.
I use a very small flame (Little Torch, oxy-propane, tip size 4).
Grasp the link to be soldered in locking tweezers to stabilize it and
protect the other links, and give you both hands free. Take your
soldering pick and dip it in your flux, then put just a drop or two
of flux on the seam. Have little pieces of solder ready. Heat the
seam gently so that the flux bubbles up then settles down, dip your
pick in the flux again and pick up a piece of solder, then transfer
the solder onto the seam. Heat again until it flows into the seam.
Needless to say, the ends must be butted up tightly, preferably with
no visible gap. Done well, you can’t even see the solder. I have to
give credit and thanks to DX Ross for teaching me this method. Once
you get the hang of it, it goes pretty fast. Also, I solder link by
link as I create the chain. Trying to go back afterwards is a real
pain.
If I am working with fine silver, I saw by hand as I have found that
the links fuse more consistently that way. I use brass tubing to
wrap the links (tightly!! neatness counts!!), and then scoot the coil
up to the edge and saw the links right on the tube. Works like a
charm, as long as you are careful to saw on an angle and not catch
the back of the other side.
My favorite chain books are Classical Loop in Loop Chains by Jean
Stark and Josephine Smith and Chain Making Link by Link by Jeanne
Jerousek-McAninch.
I also found some really excellent step-by-step instructions with
great pictures at http://bijoux-de-terre.com/, clink on “For our
students” on the left. They also have about aspect
ratios for different chains, which is quite useful.
Ann Kinsinger
http://lilikoijewelry.com
