What bur tool do I use to make my prongs on a setting I have made
more rounded or smooth?
Thanks!
Anne
Thanks!
Anne
What bur tool do I use to make my prongs on a setting I have made more rounded or smooth?
You can use a cup bur, just select the right size. I generally finish
prong tips with a barrette file and follow up with a pumice wheel.
Cup burr
Anne- They are called Cup Burrs. Easy to use, but more easy to chip
stones with them. I only use them on small diamond melle. If you are
setting colored stones or a larger center stone it’s always best to
smooth and polish the edges of a fine cut triangle shaped needle
file or barrette file to make it a safety file and dress the prongs
with it by hand.
Jo Haemer
www.timothywgreen.com
Hi Anne
This type of bur you need they call them cup bur
goog luck
Raffi
[Edit]
Attachment removed:
How can I share files and pictures with the list?
http://www.ganoksin.com/gnkurl/ftp
Or… send the files to the attention of service@ganoksin.com and
we will upload them for you…
[/Edit]
A cup bur that is size appropriate for the prong.
~Susan
