Hello everyone! I just made some castings out of bronze, and since I
love texturing and colors on jewels, I would like to know if any of
you knows of a good brand of bronze oxidizer. Are there different
brands for different alloys? I tried oxidizing my bronze jewelry with
silver oxidizer, but the results are not good and you have to
literally boil the thing to have it tarnish.
Try Birchwood Casey “Brassblack” available at a lot of gun shops.
This contains selenium which is toxic so be careful with it . Also
liver of sulfur is normally used . This can be found at Rio Grande or
most similar craft supply houses.
Benoit, Go to the local gun shop, ask for “Brass Black”. Brass can
often be patina’d the same as bronze, plenty of references out there.
Check a jewelry supplier who carries books like Stuller, Rio Grande,
etc.
I dipped my cast bronze figures in Liver of Sulphur and got
some great colors. The figures are small and inside; after a year the
color is still holding.
There are many. What color are you after??? If black—brown, liver
of sulfur will do the trick, getting different colors with different
metal, liquid temps and different concentrations (a pea sized chunk
in a cup of water is a good starting concentration to be diluted upon
use, different concentrations giving different colors). This
chemical will darken with age.
Ammonium Sulfide , most any garden sprays containing forms of sulfur
will work for differing gradations of black/brown.
Gun blueing (sporting goods stores) which are mostly formulated for
steel gun parts will almost always work to a good degree on coppers,
try brushing with a brass/bronze bristle brush while the chemistries
are reacting for different colors. Birchwood Casey makes many of the
gun blueing chemicals and also make black and brown coloring
formulas, but normally found by the gallon or more ($100’s per
gallon).
Urine, copper sulfate, copper nitrate, copper chloride, will give
greens blues.
There are MANY other chemicals and colors available but most all of
them will not ware well on warn jewelry and the body acids and salts
from skin contact will cause blue/greens to develop of warn
contacting the skin.
There are a couple of books on patinas (search on Amazon for patinas)
and availability of mixed formulas from a couple of companies. Check
at some of the good (large) art stores (Dick Blick for one) as they
might have them. Also Sculpt Novou in Escondido Califorina sells
them. Again check the web (I am not near my address file but I know
Sculpt Novou has a web site.
