"Gold is almost completely resistant to air, water and acids,
and can be dissolved only by a strong acid called aqua regia. It
is attacked by free chlorine, potassium and sodium cyanides,
bromium and some other chemicals..."
G’day; here I go again pokin’ me silly ole’ nose in. I beg to differ
there. There ain’t no sich animal as BROMIUM However, I’m sure that
was a typographical mistake; what you really intended to write was
BROMINE of course, wasn’t it?.
Bromine is is a liquid at room temperature, but leave the bottle in
the sun and it will explode into violently choking Bromine gas. It
is one of the heaviest of all liquids, (mercury don’t count; it’s a
metal) is very dark brown in colour, is very corrosive and very
poisonous. It is also expensive and I’ve never understood why it is
used sometimes as a pool disinfectant instead of common bleach,
(sodium hypochlorite) or better, ‘pool chlorine’. (Sodium
Dichloroisocyanate)
Bromine may be made by heating any bromide salt with strong
sulphuric acid. Heating bromides with almost any other acid will
produce hydrobromic acid gas, which is analogous to hydrochloric
acid, only more corrosive and poisonous. It attacks gold much better
than chlorine. Burns badly if in contact with skin. Thoroughly
nasty.
And by the way, have you noticed that most metals end in the suffix:
‘um’?
S’right: Latin was the first to name them; iron is ferrum. lead is
plumbum, gold is aurum, mercury is hydrargyrum, copper is cuprum, tin
is stannum. … But to be awkward, salts of ammonia are written
’ammonium’ . Why? because the ammonia radical has many of the
properties of a metal; you can make ammonium and mercury amalgam, a
solid. Ain’t science confusin’? – Cheers for now, John Burgess;
@John_Burgess2 of Mapua, Nelson NZ
