Thinking out loud, is there such a device that can pattern out
the curve in order to better cut the bezel to shape? The earlier
suggestions seemed a bit labor intensive.
I use a contour gauge for some things. Seems to me it would
work on the bracelet at the point the bezel should go, though I
haven’t tried it for that.
The device is like a tight, single row of pins retained by a
bar. The pins are free to move up or down through the retaining
bar. When you press the edge of the row of pins onto a surface,
the pins move up as they contact the surface. The orientation is
held by the tension in the bar which allows you to copy the
contour and use it as a pattern and transfer it to your material.
Pam Chott
