The disadvantage of premade bezels is that you can only use calibrated cabs and stones. If you don't do lapidary and cut your own stones, or buy really interesting stones with baroque or non-standard shapes--I guess you're ok. But you're missing out on a lot design-wise.
I have to say I totaly disagree with this statement… Pre-made
bezels in the long run are very inexpensive… And Just because
the perfect size bezel does not exist for all stones, calibrated
or non calibrated, doesn’t mean they wont work… If you have an
odd size stone that needs a bezel… Simply buy a bezel bigger
than what you need and simply run a seperating disk thru one
side if it is a round bezel and use hard solder to solder it back
together… Bezels can be sized with alot less aggrivation than
buying bezel wire and trying to make bezels without breaking the
stone you are making them for…colored stones that is… (if the
bezel is for example an emerald cut bezel than cut one side at a
time solder togetherand repeat on the opposing sides… rember to
always use hard solder when sizing bezels… that way when you
sweat them to your piece they won’t come apart…)
Marc Williams
MarcCo. Jewelry Mfg.MarcCo
Jewelry Mfg…
