Jim said,
Didn’t know they were called tube setting… will look up the tube
setting thread, of recent discussions… but still would like to
acquire a reasonable bezel set whatever they are called?? <<
I’m not sure the shape & number in the set you’re talking about
, Jim. If it’s the one I’m thinking of it’s a round steel shaft
with a tappered (V shapped) hole in one end. The V is probably
relatively steep. The apex angle is about 60 deg?
If that’s the case, some machinist could turn them for you from
drill rod & then harden & polish them. You could do the hardening
& polishing yourself & save a few $. I’ve not seen any in any
bodys catalog.
Dave
