There are a few low temp melting alloys available. Woods Metal has
been mentioned as well as Cerrosafe. Although they have the same
alloy components, the proportions differ for each of them.
Cerrosafe:
(% by wt) Bismuth 42.5%, Lead 37.7%, Tin 11.3%, Cadmium 8.5%.
Woods Metal:
(% by wt) Bismuth 50%, Lead 25% Tin 12.5%, Cadmium 12.5%.
Woods Metal is known to swell upon cooling and can be difficult to
remove as a positive casting. Cerrosafe, on the other hand, contracts
in the first 30 minutes, then swells afterwards as follows:
. 2 minutes -.0004"
. 6 minutes -.0007"
. 30 minutes -.0009"
. 1 hour +-.0000"
. 2 hours +.0016"
. 5 hours +.0018"
. 7 hours +.0019"
. 10 hours +.0019"
. 24 hours +.0022"
. 96 hours +.0025"
. 200 hours +.0025"
. 500 hours +.0025"
For applications requiring the greatest precision in measurement a
Cerrosafe casting is measured after 60 minutes. The rate of
contraction and expansion is well known by toolmakers.
Woods Metal melts between 163.4F and 170.6F. Cerrosafe melts between
158F and 190.4F. Both will melt at less than the boiling point of
water. Many suggest that a double boiling arrangement be used to melt
them without direct heat. Seeing that both lead and cadmium are
alloys of both, the application of direct heat could be deemed a bad
idea.
For use in filling a 2.5mm ID tube I would choose the Cerrosafe. I’d
use a turkey baster made of metal. I can see plugging the hole with
high temp RTV, then after curing, making a hole in which to place the
tube. I’d wrap the tube in something like aluminum foil (a few
layers), then warm it in boiling water or in a steamer while hooked
up to the baster. When the Cerrosafe was melted I’d quickly place the
tube into it and use the bulb of the baster to draw it into the tube.
A few layers of folded aluminum foil would be enough to hold against
the end of the tube to prevent it from running out before cooling.
Once cooled you could easily wrap it around a mandrel, cut it, then
boil it in water to remove the Cerrosafe. Once the water has cooled,
I’m sure you could gather the Cerrosafe, dry it, and reuse it.
As Orchid readers are aware, there is always more than one way to
skin a cat. I’m sure there are other’s that’ll have better ways to
skin this one.
Mike DeBurgh, GJG
Alliance, OH
