Hi, All!
I need some advice.
I have a gold ring that has a thin rectangular piece that got bent
back about 90 degrees from where it should be and twisted very
slightly.
This piece is part of the shank continues beyond where it would
normally stop and wraps around the head. It’s a love knot design.
The part that is bent back is 1mm thick, 2.8mm wide and 9mm long. It
does look like the gold is slightly stressed. There is a 1 carat
diamond right next to the stress mark.
What would be the best procedure to bend this piece back around the
head. Should I just bend it or use heat on it or any other
suggestions? I would like to not use heat if at all possible. If I
bend it back without using heat what are the odds of it breaking at
the stress mark.
Thank you for any help.
Randy Jacobson
