Now showing at the BenchTube
How to solder tiny ring components
Runtime: 6m 14s
I was recently asked for some advice on how to solder a very small
bezel setting to a thin wire band. This is a how to explaining the
process, and helping you to avoid some common issues, such as work
coming apart or moving while you solder, and excessive solder
causing a buildup around the setting in situations where there is
very little surface contact…
Watch Video:
