In this video, I explain the differences between many hammers &
clamps prior to setting any style of ring. The optimum phrase is
‘being comfortable’ in setting stones. You don’t want your hand to
hurt or have your clamp literally fall into pieces! Your hammer
should weigh just enough you the results you need. But the hammer
must not be too heavy or your hand will get tired. “A tired hand
gives you poor results!”
Is it only my Firefox/Win7 setup, but the audio in these videos is
so far out of sync with the video that in many cases I’ve no idea as
to what the description is referring.
I view on Firefox/Win 7 also and the audio is off by 5 to 10 seconds.
quite a lot! I am curious to know if anyone is viewing the videos
with the audio in sync? And if so, what is causing the difference?
It’s a glitch with Shockwave Flash and happens off and on with
various browsers and operating systems. It used to be a lot more
common. Try running the updater for your flash driver.
