Hi Annabel,
I stopped using crimps on my SoftFlex and Beadalon pieces after I
had a couple necklaces break in my hands while showing them to a
wholesale customer (fortunately, a good and understanding customer).
Haven’t used them for years… and it never ceases to amaze me to see
them on expensive pieces in that jewelry catalog out of Utah that we
all love to browse. You can knot either of these stringing products,
which is how I end my strung pieces when I use nylon coated wire. It
takes a bit of practice to get a knot nice and tight into a bead tip,
but I’ve only had them break when a customer wears them every
day… for long periods of time. They are, after all, just wire under
that nylon coat … and excessive wear (in both senses of the word)
will ultimately break the wire. What will occasionally happen with
the bead tip ending is that a customer catches the clasp on
something, the bead tip opens, and the clasp falls off … but the
rest of the piece remains intact. No beads all over the floor. I get
a lot of “repairs” of this kind on bracelets (people are hard on
bracelets). But only rarely do I have to do anything other than
replace the clasp piece that was lost or just re-attach it to the
bead tip.
The routine I use is to tie a couple knots into one tidy knot on one
end of my nylon coated wire (three knots, if using.010 in. diameter
wire), leaving about a 1/4 to a 1/2 inch tail, and string through a
bead tip… then string the piece, including the second bead tip. Set
the piece down, make a loop in the end of your wire and with a T pin
inside the loop pull it as close to the bead tip cup as possible.
Pick up a small pair of round nose pliers, position them on the side
of the loop opposite the bead tip cup (so that the loop is between
the round nose pliers and the bead tip), pick up a pair of flat nose
pliers to use as a grip on the end of the wire, pull on the wire and
slide the round nose pliers to tighten the loop into a knot and move
it closer to the bead tip. Don’t worry if there’s a small space
between the knot and bead tip when you’re done, because you’re going
to do it again. Just make sure that when you make a second loop and
repeat the pulling and tightening of the wire, that the second loop
sets between the first knot and the bead tip. If you’ve done it
correctly, the second knot will take up the space left between the
first knot and the bead tip. Cut the excess wire, again leaving a bit
of a tail. To assure the knot stays put and doesn’t unravel, take a
lighter to the “tail” on each end… once you get comfortable with
this procedure, you can even allow the melting process that occurs to
continue into the knot itself. Snip the residue close to avoid
leaving anything outside the perimeter of the bead tip that might
scratch skin. If you have a little black on your bead tip, just
shine it off with a jewelry cleaning cloth before attaching your
clasp.
Hope that helps… it probably sounds more complicated than it is,
but it’s worth the effort to avoid having customers come back to you
with half the beads from a piece because your crimp bead broke.
I also use this procedure as a sort of marketing ploy at shows: at
some of the smaller shows I do in my area, almost without exception
all other strung jewelry in the show end in crimp beads; I make it a
point to educate on this point - and have even gotten restringing
jobs when customers have brought me pieces made by others to restring
using bead tips. At one show where I was the first booth in the door,
I had a lot of people stop and look, listen to my bead tip spiel if
the opportunity presented itself, and return after viewing all the
crimp beads at other booths. I educate on other topics as well, but
this one seems to make it’s way into their brains and makes an
impression… crimp beads - break and lose; bead tips, open up but
retain.
Depending upon the beads you use, and their heft, you may want to
also consider stringing on beading chain. I really don’t like using
SoftFlex’s “heavy” wire (.024 in. diameter) because the knots are
rather large and require a different size bead tip. If you’ve got
beads heavy enough to require.024 in. diameter wire, beading chain is
probably a viable alternative.
Good luck!
Karan
