thanks a lot for your detailed analysis. It sure does seem porous or grainy and that is probably as you said is what makes the color deeper.
That “grainy” texture is not an intrinsic property of the alloy.
it’s a deliberately applied surface texture. most likely done by sand
blasting, from the look of it.
And the color IS deeper; I saw a pair of earrings by myself on time in HongKong airport quite a while ago (and that is how i started looking for about purple gold).
Remember that the depth of color you see is in great degree affected
by the reflectivity of the metal. A highly polished surface will show
much less of it’s own color, and more of the reflected colors of items
around it. Look at how much more yellow, a normal gold item appears
with a “brushed” or satin finish, compared with a highly polished
one. And of course, the light source also will have a lot to do with
how you percieve the color of a thing.
Admitting it is the same alloy that you have been using, does purple gold require special care (apart from not banging it), i mean can the normal cleaning solutions be used or could that damage the alloy?
I’ve not actually made much jewelry with it and tracked it’s
performance. My own uses have been mostly small experiments, and then
I moved on to other interests after finding that the types of designs
I wanted to do were not suited well to purple gold. But from what
little experience I do have, I’d guess that normal wear should not
cause problems, and that the usual cleaning agents, so long as
they’re not especially harsh chemicals, should be just fine. But you
should ask these specific questions of any vendor you buy something
from, as they will know the precise care requirements of their
merchandise much better than I do.
Peter
