How to Determine the Aspect Ratio for Making Chains
Go to this site for info on aspect ratio
http://www.ganoksin.com/gnkurl/ep80q9
Thought I might add a little.
Aspect ratio = inside diameter of loop / wire diameter
Inside diameter = wire diameter X aspect ratio
Take the wire diameter and inside loop diameter you are using now
and figure the aspect ratio using # 1.
Use this aspect ratio and the wire diameter you would like to use to
figure the new loop diameter using # 2.
There is also much additional chain maille available
from the source at http://www.ganoksin.com/gnkurl/ep80qo Click on
“For Our Students” on the left.
Cheers.
John Fetvedt
bijoux-de-terre.com
Can highly recommend the link below! I use it often and find it VERY
helpful! John Fetvedt is a GREAT teacher if you want to learn chain
making!!!
Beth Wicker
Three Cats and a Dog Design Studio
